RCU Forums - View Single Post - Low Wing 40 size plane?
Old 05-03-2004 | 07:39 PM
RevGQ's Avatar
RevGQ
Default RE: Low Wing 40 size plane?
My condolences. If it has not been suggested, consider the Great Planes Cap. I am just finishing mine. It took me only one evening to trace all the parts to poster board (I only purchase kits once). I am putting a GMS .76 up front, and so far the balance looks about right. Building went without a hitch for the most part, just take a good look at how the fuselage fits together prior to glueing. The top doesn't quite fit the sides as the plans call for, but it is nothing you can not think your way around.
P.S. It would be advantageous to learn to use the rudder, particularly in high wind conditions. Using the rudder, you practically make your turns with the wings level. Just a thought. Good luck on your choice.
