RCU Forums - View Single Post - Hitec laser 4 TX problem.
Old 05-03-2004 | 09:43 PM
DBCherry
Default RE: Hitec laser 4 TX problem.
By the way, the new Futaba plugs suck. They're set up so that you have to remove the back of the transmitter to access the plug, and it's different than any other connector out there. [:@]
You can easily make a connector out of a standard connector (the side with the pins) by simply breaking off the outer housing. I'll be making up some adapters for my transmitter packs so that I can remove the pack without opening the Tx case.
Dennis-
