RE: Scanner CG - Add weight or larger engine?
Hi,
Thanks for the information on the CG and the clevis.
I had bent one of the plastic pins in the clevis when twisting it on the wire. I suspected they were not very strong, but was going to use them anyways. You probably saved me a plane with your advise. Thanks.
I don't like to add weight and I was wondering if I should install a .60 engine instead, the CG would be about right, but I'm concerned that the plane may not take the extra power.
Thanks for getting back to me.
Fly4Fun,
Wayne
