RE: Setting thrust line ?
Zep, I am currently tuneing my thrust angle, not to be confused with thrustline, which I think rcFp was referring to. On the thrust angle, unfortunatly it is trial and error. You are on the right track by first ensureing that the control surfaces are set up properly. I have completed the vertical to check for right thrust and am now in the process of determineing if any up/down thrust is needed. Joe
