RCU Forums - View Single Post - warped wing...need help
Old 05-04-2004 | 05:27 PM
Stew99
Default RE: warped wing...need help
Wetting it with an ammonia and water solution should work but first make sure the shuck itself is not warped before you put the wing back in. If it is you will have to find some other way to twist the wing back to the correct shape while it dries. If it was cut with a warp you might have to go for a new wing panel.
