RCU Forums - View Single Post - CRYTAL PROBLEM,IS A PCM CRYSTAL DIFFERENT?
Old 05-04-2004 | 06:28 PM
FHHuber
Banned
Default RE: CRYTAL PROBLEM,IS A PCM CRYSTAL DIFFERENT?
Assuming the crystal in the TX is the original... the Super-7 SHOULD work with the 127DF RX using the 72-10 crystal if the crystals, TX and RX are all good.
Something is broken.
first try the RX crystal in a different RX.
Then try to operate the RX with a different TX.
Then if the problem has not been identified I'd be boxing it up and sending it to Radio South. It'd probably be a $60 repair bill (might be mre... might be less... never much less [&:]) but it would be RIGHT.
