RCU Forums - View Single Post - 7CAP - lost endpoints after timer setup
Old 05-04-2004 | 08:12 PM
Dsegal
Default RE: 7CAP - lost endpoints after timer setup
> How weird? Just by chance I happened to come across this thread, and I have had the same exact problem. I just bought a 7cap today and was getting it all set up. Had it ready to go, and was testing the timer. I just happened to move the ailerons and the right side was dead. <
A few days ago I took my new 7CAP to the field for the first time. As I had a repaired aircraft, I decided to do the test flights with the old transmitter. It flew fine so then I turned on the 7CAP to do a ground check and was puzzled why my right aileron servo was not working. I thought that I had made a mistake in setting it up. Now I know the truth. Thanks to all of you guys for making us aware of this problem. Futaba had better get off their butts and deal with it.
P.S. I checked the other two models I had programmed and the problem hit them also.
