Side load, or thrust, is what the prop, pulling on the crank, does to the bearing...
Radial is what the piston, pushing down on the crank, does to the bearing...
Don't know how torsional applies to a bearing, it's usually the twisting force applied to a shaft, as in a torsion bar..
