RCU Forums - View Single Post - In kit building when to use CA and when to use epoy?
Old 06-29-2002 | 08:57 PM
EXCAP232
My Feedback: (12)
Default Titebond
For model use the regular Titebond is the preferred glue. Use the Titebond 2 only if you plan to fly off water. Regular is much easier to use as the open time and shelf life differ between the two. Titebond will set up so calmps can be removed from a good joint in as little as 15 minutes. If you need to remove a joint water will do the trick as well as heat. Yes, I do work in the woodworking industry. Bill
