RCU Forums - View Single Post - In kit building when to use CA and when to use epoy?
Old 06-29-2002 | 10:10 PM
f2racer
Default Re: titebond
Originally posted by Buz^
if you suggest titebond as i also use at times, give him more imfo, ONLY USE TITEBOND II, as its the only waterproof titebond
I believe the 2 formula is actually weaker than the original. Whatever, it can't possibly be stronger (I've done some testing and Titebond is as strong as 30 minute epoxy in any joint). Plus you really don't need it since you cover any areas that you'll use the glue on. As Bill state, unless you plan on using floats or flying in the rain (which some people do), use the original formula.
