RCU Forums - View Single Post - Is there a difference ?
Old 06-04-2003 | 01:18 PM
ballgunner 's Avatar
ballgunner
Default Is there a difference ?
There is definitely a difference between pusher and tractor props. As you get into electrics you will discover that a tractor prop will operate as a pusher by reversing the leads on your motor. With nitro power you will have to get a real pusher prop. They are readily available from most major manufacturers. Pushers when operated properly have the blades reversed from regular props. Check with your hobby shop.
