RCU Forums - View Single Post - How can I ensure Equal throw for elevators halves???
Old 05-06-2004 | 08:31 PM
ramcfarland's Avatar
ramcfarland
My Feedback: (44)
Default How can I ensure Equal throw for elevators halves???
This is my first dual elevator set up using an individual channel for each servo actuated elevator half: in my case using a new Airtronics RD-8000 which uses channels#1 and # 7,to do the job---After first "eye balling" the throws between the left and right elevator halves, it became readily apparent I'm not at all sure as to the accuracy using the 'sighting technique' to insure that the elevator halves are equal in travel through their range of travel either up or down in their deflection,on my Great Planes Wagstaff. I recently purchased the Great Planes throw meter which uses a protractor to measure degrees of throw HOWEVER---It appears rather (in accurate) for what I'm trying to accomplish..
WHAT TECHNIQUE /THROW METERS DO I NEED TO ACCURATELY ADJUST FOR EQUAL ELEVATOR TRAVEL THROUGH OUT THEIR RANGE OF TRAVEL?
Thank you!
Richard Mcfarland AMA52920
