RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 05-08-2004 | 09:48 AM
  #2200
AcroJo's Avatar
AcroJo
Default RE: U Can Do 60
Coo, I ran the 15/6 since late 2002 and just found that it was at the top of the throttle rang in a hover. With the 15/4 it is now just below 3/4 throttle leaving that last quarter for pull put.
Steve, on the maiden of this one I thought that I would leave it off untill I got the thrust issue dialed in and any carb adjustments. What I found was that It had a very nose high attitude and when inverted it was if it was severly nose heavy. It stopped with the cowl on. I felt that the ramp under the front of the fuse responded as an air foil pushing on the nose from below. Joe
