I'm building a Balsa USA Stick 40 Plus.I saw elsewhere on the site that the wing needs some re-enforcement .I was going to use Fiberglass tape on the center section anyway but I'm also going to use shear webs.My question is,Iwant to eleminate the aileron linkage on the plans (nyrods with a single servo In the center section)to dual servos one in in each wing.What's your opinion?I'm going to use either standard 'Hitec servos or HS-81"s.Whats the best way to route the servo wires through the wing/?I was going to lay string in the rib bays to pull the cables through after covering.Any other suggestions?This is my first post onthe site so be gentle
