RCU Forums - View Single Post - AMA Spinner Ruling
Old 05-08-2004 | 09:16 PM
FHHuber
Banned
Default RE: AMA Spinner Ruling
ORIGINAL: J_R
ORIGINAL: FHHuber
<SNIP>
There is such a thing as an "AMA Safety nut (which is essentially a large "acorn" nut) But its only required for certain types of competition.
<SNIP>
Although I have searched the AMA site high and low, and looked at other doucments, I can not find an "AMA Safety nut". I did find AMA shirts, AMA cups, AMA pins and many other items.
At this point, I think the only thing "AMA Safety nut" refers to is you... and then, only in your dreams.
So far, your posts are without merit on the subject of spinners. Do the research and try again.
http://www.modelaircraft.org/templat...k/rccombat.pdf
Section 3.4.2 under the scale competition rules
READ IT and SHUT UP
3.2 under the "open" class has essentially THE SAME wording
Should I bother finding other AMA docs that specificly mention an "AMA Safety Nut" or have you been sufficiently humiliated?
Tyoped a number
Events if you are looking for them and can't read... competition Event 750 for scale RC Combat and 755 for "open" RC Combat.
Icing on the crow pie for J_R:
http://www.prop-shop.com/SPINHUBS.HTM
FOX 6504 AMA SAFTEY SPINN NUT 1/4-28 SH.....$ 5.00
http://www.prop-shop.com/g/f/fox60504.jpg
