RCU Forums - View Single Post - GP Super Stearman
Old 05-08-2004 | 10:38 PM
  #76
John_RedSox
My Feedback: (75)
Default RE: GP Super Stearman
Mine should be ready by for next weekend. The connecting rod for the ailerons I found did not provide enough throw for the bottom aileron. So I moved the bottom horn which alleviates the problem. Even though the rods are not parallel by dong this, I will sacrifice that to compensate having more aileron throw. I also covered the top wing seam from the wings being glued together. GP should supply some extra covering but I ordered extra red and wasn't too expensive. The kill and receiver switch are in the cockpits which I added gray carpet.. I also altered one of the pilots because the one's that come with it are too similar. I used the "Bennett" easy carb adapter for hookup. Makes things a bit easier. I'm also changing the decals to vinyl. The ones that came with it don't match very well. Overall I'm very pleased with the plane.
