RE: Help with avatar
HI rdcracer
first using your editor crop the picture to just include the image and save as jpg <normal> if you have the normal option. it must be jpg, cannot be bmp, I think. then reload the saved image and go to image properties and resize to around 80x60 pixels <may have to play a little with these numbers> mine is 80x60. this should put you in the ballpark. I am using editor that came with my digital camera but lots of other should work. don't think you can use windows paint. what editor are you using to resize image?
good luck hope this helps happy flying
joe
