RCU Forums - View Single Post - Does braking on down lines make engine die?
Old 05-09-2004 | 02:22 PM
jaka
Default RE: Does braking on down lines make engine die?
Hi!
Don't agree with you!
Take a Du-Bro or Sullivan 4-15 oz tank...where is the space for the fuel line and clunk up front and for it to reposition to it's original place just 1 cm from the rear wall of the tank ??
No! Do as the tank manufacturer says: on every thank solder a piece of brass tubing to the clunk so that the clunk can't bend forward.This set-up is proven to work in practice.
Or better yeat.... get a Tettra "bubbleless" fultank that doesn't use a clunk at all.
Regards!
Jan K
Sweden
