RE: Low speed needle fully closed
Firstly, unscrew the needle until it's flush with the black housing, then, hold the carb shut with your fingers (well as far as your idle adjustment will let you, (1-2mm open)) Then screw in the LSN until you feel a slight resistance compared to normal turning, your LSN is now closed. DO NOT OVER TIGHTEN THIS NEEDLE!!!!!! you will kill the jet where the fuel goes into the carb.
