RE: Trim for level flight throttle settings
A plane is USUALLY trimmed at ABOUT 1/2 throttle....... the throttle setting where you do the majority of your flying.
You should not have to constantly adjust the trim settings.
Once the trims are set, about the only time you MIGHT change them would be if there is more wind than usual.
