RCU Forums - View Single Post - pixi programming question
Old 05-10-2004 | 05:53 PM
justin_92_92
Default RE: pixi programming question
well I can get it to turn on the tail(arm) but my tail is pulsating. it only shoots jolts of power. you think I need to charge this lipo up? I cant get off the ground full throttle so I think that may be a reason? Not too sure....how much fiddling with the screw on the hh gyro did you have to do?
ALso when I cut the power or run at very low head speed the heli screaches....almost sounds like a break that stops the motor....you think it could be my johnson 250...if so I have more motors...but like I said it sounds almost like a break of some sort. weird
