RCU Forums - View Single Post - Aileron Trim
Thread: Aileron Trim
Old 05-10-2004 | 09:28 PM
vinnie
Default RE: Aileron Trim
With the ailerons at neutral, try trimming for level flight using rudder trim only. Then try some turns and see if the response is more normal. If it is, take a closer look at the vertical stab/rudder alignment with the fuselage. Check for wing warpage as well.
