RCU Forums - View Single Post - Aileron Trim
Thread: Aileron Trim
Old 05-10-2004 | 09:39 PM
FHHuber
Banned
Default RE: Aileron Trim
The nosewheel has essentially no effect on how the model behaves in the air. (on th ground it has a large effect)
The engine thrust line being incorrect can have the effect you are refferencing.
Also... having the RUDDER offset can cause you to "cross-correct" with ailerons... (this can get dangerous... cross-correcting is inviting a stall-spin on final approach.)
