RCU Forums - View Single Post - Nylon pin-hinges really that much better than CA-type?
Old 05-10-2004 | 10:00 PM
bentgear
Default RE: Nylon pin-hinges really that much better than CA-type?
Just remember that if you are going after large throws (45 deg +) then don't butt the surfaces tightly together. With that much defection you need a SMALL gap so the CA hinge has room to flex. Go back and seal the gaps with covering material or tape no matter what type hinge you go with.
Ed M.
