RE: High idle speed before landing
Idle speed is set in yout transmitter by using the ATV function to set the throttle servo "End Point," or minimum setting.
If your setting keeps changing, check your throttle cable for binding, or on the other hand, flexing.
Either of these extremeties can prevent the throttle from closing in fully when the Tx throttle stick is moved to the idle position.
