RCU Forums - View Single Post - Scanner CG - Add weight or larger engine?
Old 05-11-2004 | 07:43 AM
Wayne Miller
Default RE: Scanner CG - Add weight or larger engine?
Hi tIANci,
Since our last post we have had quite a bit of rain and the field is very wet. When this happens at our field, you can gather speed while on the dry areas, but it almost comes to a stop when it hits the wet area. As a result, I wanted to hold off on the maiden flight until the field is reasonably dry.
Hopefully I'll be able to fly today. I'll let you know how it flew as soon as I get it in the air.
Were you able to repair yours?
Fly4Fun,
Wayne
