RE: Nylon pin-hinges really that much better than CA-type?
I've been using Pacer hinge glue on my CA hinges instead of CA and it gives you more time to install
and straighten the hinge plus clean up is real easy. I tried it on some scrap balsa before
I used it on my plane and the balsa shattered before the hinge came out. It also doesn't make the hinge
stiff the way CA does.
tommy s
