Hi guys,
In modifying my plane, I noticed today that my tank sits MUCH lower than the carburator intake. I'm thinking this may be a problem, even though the tank will be lightly pressurized by part of the exhaust gas.
Before I cover the front part of the plane, I want to make sure I haven't made any severe mistakes. So, if it IS too high (keeping in mind the photo is pretty much level, so it is an accurate representation), which of these would you suggest?
* Cut landing gear and move it down.
* Bend landing gear (as I have done) and thus lower the front part more. (the gear is very strong, and the plane being slightly more than a pound, even rough landings should pose no problems).
I don't foresee doing many aerobatic moves, if that is of any relevance.
Thanks in advance!
EDIT: I have marked the tank output, the tank outline, and the fuel collection weight from left to right, respectively.
