RCU Forums - View Single Post - Blackhorse Kit
Old 05-12-2004 | 01:45 PM
bassmanh
Default RE: Blackhorse Kit
beltdrive,
if you mean the blackhorse ARF`S yes i have put the speed air 40 together, it goes together very easy and the instructions were good and it flies great with a .46 in it. it has a good parts bag and the plane even came with the pilot already installed.
the plane flies VERY WELL can do most of the arobatics and can fly fast or slow and it slows down nicely for landings as well.
the only thing i would do is to make sure you have the vertical stab glued very well as the tail is thin and mine started to crack after MANY flights but was easy to fix. other than that its been a great plane and i have been thinking about getting another black horse plane in a diffferent model. good luck and if you get one i think you will like them .
bassman
