RCU Forums - View Single Post - Hitec Servo timing
Old 05-12-2004 | 01:58 PM
brownknows
Default RE: Hitec Servo timing
Has to be some difference in the mechanical connections then. The push-rods are not equidistant from servo shaft on the servo arm or not in the same holes on the control horn. Either way this will make for a bad day when you try to fly it.
