RCU Forums - View Single Post - Plane Stands
Thread: Plane Stands
Old 05-12-2004 | 02:39 PM
  #57
Walfam
Default RE: Plane Stands
I use a couple of stands
1. Using 2 pieces for heavy foam I cut out one for the tail and one for the nose of the plane, and then run some pvc thru the bottom.
this gives me a stand to set the plane on at the field and I can put it on the top side when not in use.
2. using a handicap walker I put the same pieces of foam on each section where your hands would go and it makes a great
plane holder and folds up when not in use.
