H9 CAP 232 25% elevator question
Yup, I did the same thing. Did you know that the supplied elevator pushrod is exactly the correct thickness? Two pieces, cut to fit into the corner of the elevator frame and glued securely, do the trick. A little white U-Cote, and nobody will ever know...<G>
Steve
