Help needed with OS 46FX
I have a low time OS 46 FX (about 1/2 gallon through it) I have had since new. After the using for the last time last year, it was run dry of fuel, after run oil put in and stored in a dry location.
The engine HAD BEEN running last year with the main needle open 2 1/2 - 2 3/4 turns. Low end has not been touched since it was set. The engine is in a new plane mounted sidways.
Problem: It will not run beyond the prime.
I have done/checked the following and am at a loss on where to go from here.
New OS #8 plug (verified the plug is good - All coils, except the top 1/2 are lit and bright)
Fuel is getting to the carb
Fuel is fresh (Jug was opened yesterday and put on the field box)
Fuel tank/carb height is correct
Compression is excellent
Made sure the main needle valve has no junk/crud in it. (Removed and cleaned the needle valve, blew out the housing and visually verified the housing is clear and there are no burrs or anything on the needle valve.)
Replaced ALL the fuel lines, including the tank lines and made sure they were tight
Made sure the clunk was clear and free moving (tank is new)
Pressure tested the tank, everything is tight - no leaks
There are no kinks in the lines
Used the power panel with the votage set a 3 volts for the glo plug.
Tried various main needle valve settings up to and including 4 1/2 turns - no difference
The engine primes easily. It runs out the prime, then quits. Any ideas on where to go from here ? It SHOULD run, but it isn't The engine ran great before I put it away last year.
