RCU Forums - View Single Post - Saito 72 new engine run problems
Old 05-12-2004 | 06:48 PM
Stick Jammer
Default RE: Saito 72 new engine run problems
MinnFlyer and daveopam are right. You leaned the high speed needle too much and WAY too soon. 10 - 15 minutes is not nearly enough run time to be crankin' at 9000 rpm's with a lean setting. Read the break-in info again. I don't think you're following what is recommended. As already mentioned, Cool Power 15% is fine.
