RE: Problem with Tank & Carb Levels
I had a similar issue with an OS52 in a Mid-Star. Engine ran great until I inverted the plane. Then the mixture richened up since the carburetor no longer had to pull the fuel from the bottom of the tank. This made a difference since the bottom and top of the tank were not the same distance from the carburetor centerline. I finally installed a Perry VP20 pump and it runs great at all attitudes now.
