RE: Help needed with OS 46FX
The next things to check are for leaks in the rear cover gasket (loose or missing bolts) followed by checking out the low speed needle. Put a clean piece of fuel line on the carb nipple and see if you can blow air into the carb at all but the fully closed position. There may be a blockage in the low speed needle if you can't blow through the nipple.
