RCU Forums - View Single Post - Engine vibration
Old 05-13-2004 | 03:08 AM
siclick33
Default RE: Engine vibration
Do you pinch the fuel line and let , or pinch it and hold it?
If you hold it then the engine will obviuosly stop. You need to let go to hear the RPM change. If you are letting go, and it is stopping afterwards, then I would richen your engine quite a bit and try again. If you don't then you run the risk of damaging the engine.
