RE: Help me slow down.
Moving the CG back will help a lot. It will allow you to pull the nose up at low throttle settings, which will slow you way down. With the CG forward, the elevator has to work too hard to keep the nose up and get the wing to the high AOA you need for slow flight.
Lower prop pitch is also a very good idea, some good suggestions above.
