RE: I need help with my tc3 with a turbo nova rosi .12 motor
I'm runnning into the same problem with my new Factory Team. I question if it is because I just installed a new piston/sleeve(Mugen/Novarossi MT-12)and I haven't finished breaking it in yet. I'm also having a bit of trouble tuning it because of the mid range screw, I'm not used to it...I just installed my back-up engine(OS 12TR) and I haven't had a chance to run it to see if that was the problem. The only other thought I've had is the gear ratio, it's a big jump between gears and it might bog some engines down(shouldn't with yours or mine, lot's of power). Have you broken your engine in yet?
Let me know how you make out, and I'll do the same,
Patrick
