RE: Aileron Trim
Of couse... if you pull too hard in the high speed loop... you can do a high speed stall and snap-roll out of the loop (usually near the top of the loop) even if the airplane is straight... Some experience with seeing which is in-flight warp vs the high speed stall may be required for the test. (test works.. just need to know the catch to it.)
