Hi AnnMarie,
Somehow I would like to use the throttle side "SLIDER" to control both Spoilers & Flaps in conjunction with switch "X". Right now I'm using ch 1 & 6 for the ailerons, 2 & 8 for the elevator servos, ch 7 for the battery, and the rest in their respective channels. What I would like to be able to do is place the slider in the center of its travel (it beeps in the center) for normal flight. Then when it is slid up, control the amount of spoilers for both ailerons. Then when it is slid down from the center, control the amount of both flaps. Pick any on-off switch to make the slider active or inactive. Basically I want to be able to go from full up ailerons to full down flaps with the slide of the slider. Possible???????
