RCU Forums - View Single Post - Slider On 9C
Thread: Slider On 9C
Old 07-02-2002 | 01:00 PM
amcross
Default Slider On 9C
Mike,
You bet! Easy as can be -- go to aux2, assign ch 6 to VRD (left slider). Go to FLPTRM and make it as high as you need to to get your maximum up and down spoileron/flaperon desired (you may not want a full 100%).
now do a mix: ch 6 to ch 6 -100%, link ON, on/off on whatever switch you select. This will turn off the slider whenever the switch is in the on position.
