RCU Forums - View Single Post - Aliphatic versus Epoxy
Old 07-02-2002 | 04:43 AM
Baretta92
Default Aliphatic versus Epoxy
Hello all,
I was wondering what the differences were between using an Aliphatic Resin type of glue (All Elmers and the like) to fix foam on a busted park flyer (I am reffering to Graupner type foam on the Terry or Wingo etc) versus just using good old epoxy. Being new to this park flying buisiness (I will admit that I am hooked now though thanks to my Terry!) I assumed that one could use 5 min or 30 min epoxy sparringly to fix these planes. While flipping through the latest Backyard flyer, I noticed an article about repairing foam and the author seems to say something along the lines of "don't fall into the trap of fixing foam planes with 5 minute epoxy". Having garnered all of my RC plane experience in the glow world, Devcon 2 Ton epoxy is my best friend! The author recommends using thinned Aliphatic resin and household paper towels soaked in that mixture in lieu of epoxy and fiberglass cloth. Now, I know that Epoxy can be heavy, but if used sparingly, it should not present a weight problem. Did I miss the boat here or something? Or is Aliphatic resin that much lighter and or easier to work with? I need to fiberglass (or so I had hoped) the wing bolt bearers on my Terry. The wing is held on by only two bolts and they are positioned right next to each other. If I should by chance strike a wingtip on the ground or something ( I did this a lot getting used to my Terry, but I am trying like heck to avoid now because it wreaks such havoc on the fuselage!) a rather high leverage situation occurs where the wing can get cranked around the fuselage pivoting at the two bolts! It causes the two blind nuts that accept the wing bolts to be torn out of their holders. I have fixed this with 5 minute epoxy before and have had no real problem. I have come up with a brace made out of balsa that fits between the two wing bolt bearers that should hopefully keep them aligned. I am hoping to boltser this with some added reinforcement via glass cloth or paper towels. Which is better?
Baretta92
