RCU Forums - View Single Post - Throttle opening for idle
Old 05-13-2004 | 08:40 PM
RaptorCam's Avatar
RaptorCam
My Feedback: (14)
Default RE: Throttle opening for idle
Did what you said and after going from high to idle it will almost die then raise back up to 2800 / 3100 range appoximately. It seems to stay there. If I ever cut the throttle in the air in that state it is most likely going to die. So i tried setting the trim higher so that lowest end, where it almost dies is a bit higher. What happens then is when it raises back up the idle is way to high. Turning the regulator screw out 1/2 turn like you said puts it above being flush with the housing. I'm not questioning your setting just letting giving you an idea of where it was when I recieved it back.
