RE: Mini-Dust
Those carbon fibre push-rods are going to be a must have !!! I'm thinking I will have to machine a little steel spinner nut to balence this thing off before it is over with......The good thing is that this is only Ver. 1.0.......I'll make a few changes on Ver 2.0 to cure this problem. Or perhaps if i think it can handle the extra weight I'm going to try a norvel 074 on the fron........Any guess at how fast this goes on the 061 ??? Also...how did you do your fuel tank ??? I had to solder up a small mint can to make a tank for it that was going to fit under the hatch but then I had to start moving everything forward and it is going to stick out now...darn it !!! Anyone know how to do a bladder tank ???
