RCU Forums - View Single Post - Left Thrust?
Thread: Left Thrust?
Old 05-14-2004 | 08:28 AM
Fastsky's Avatar
Fastsky
Default RE: Left Thrust?
The NExtsar is prebuilt and the engine is preinstalled. In other words it should be fine the way it is. You say that you can notice that engine is already "leaning" to the right so it sounds like the right thrust is already built in for you. Has the plane flown yet? If it has and no problems were noted, then don't try to fix what isn't broken!
