RCU Forums - View Single Post - Throttle opening for idle
Old 05-14-2004 | 10:34 AM
RaptorCam's Avatar
RaptorCam
My Feedback: (14)
Default RE: Throttle opening for idle
Im running Wildcat YS Blend 20/20. So come out another half turn? We are at 180 feet.
Edit:
I have been out 2 full turns total from where I started, using half turns each time and trying quarter turns as well. Same results. Engine idles below 2000 after coming from full throttle and if it don't die it raises back up in the 2500/3000 range. Sometimes it stays at that high rpm and sometimes it might idle back down slowly and then die. I removed my fuel lines and tank and checked for leaks and all is fine there.
Edit:
I'm spent. I have had the engine now for a month and its had more fuel run through it on the gound than it has in the air. The only good thing I can say about this engine is that it might get a Saito 180 in swap.
