Originally posted by SwampFlier
Just for your information
JR and Airtronics ar compatible
Hitec and Futaba are compatible
MUltiplex stands by itself
Although it is not going to alter spankyhappy’s choice, I would just like to ensure that everyone knows that Multiplex does not stand on its own. It is shift compatible with, I think, JR rather than Futaba, and its receivers and servos can be bought with “uni”plugs which are JR. All their transmitters except the 3000 series have a software switch to use Multiplex or Futaba/JR servo time pulses and the 3000 series is easily adapted to centre and travel with Futaba/JR servos – I know because I use the truly magnificent Multiplex 3030 with JR Rx and Futaba Rx and everyone’s servos. In case you are wondering how I use Futaba Rx with Multiplex Tx, here in Europe we do not allow the silly shift incompatibility that you allow in the Americas.
If you want a 9 channel or more Tx, your only choice is between Multiplex, Graupner or JR. Despite Futaba’s misleading names for its Tx, the 9C and 9ZAP are 8 channel radios.
Harry
