RCU Forums - View Single Post - Nomadio Sensor Radio
Old 05-14-2004 | 02:31 PM
  #54
Desmo
Default RE: Nomadio Sensor Radio
I think you should wait and see what Nomadio comes up with. As for the mini-T, it is big enough for an aftermaket rec and ESC so unless the sensor rec is bigger than average it should be fine. The sensor radio range is no where near the 27mhz band like a mini-z. Unless someone makes a replacement rec/esc or the Nomadio rec fits with an aftermarket esc you are out of luck. I would wait if its a concern, its not like the 3PK is not good enough for the job
