RCU Forums - View Single Post - Dihedral amount for this A-26 Invader?
Old 05-14-2004 | 03:59 PM
B-24 Nut's Avatar
B-24 Nut
Default RE: Dihedral amount for this A-26 Invader?
Also...,
The plan shows 1/4" square balsa along the trailing edge. I did that.
I then deviated from the plan by trimming the foam and installing a balsa leading edge before the sheeting. Given that and that the Jack Stafford B-24's foam wing has the same balsa leading and trailing edges and then wing sheeting that is many pieces, do you think I'll be okay?
I base my work only on the B-24 kit as I've done nothing else like this.
Mike
